suffix code - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2007, 03:51 PM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
suffix code
i have a327 engine 3959512 and the suffix code is s0920xtd -ce5n21351 tell my which application is it thanks.
Old 04-12-2007, 10:28 PM
327NUT's Avatar
All I could find from Mortec ....'62-'67 and used on some replacement blocks. The suffix code info I found was pretty vague.
Old 04-13-2007, 12:04 AM
DoubleVision's Avatar
I too couldn`t find a XTD code, all I found were 2 letter suffix codes in X. This is another one with no info on yet we can add to the list. However, the CE there after has me confused somewhat, since the CE code represents a replacement warrenty engine, but most of these engines did not carry any other codes so the CE could represent something else, I`m not sure.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
suffix code = Bad news? DaSouthWon Engine 3 04-20-2006 12:28 AM
sbc engine suffix code hootis Engine 6 02-09-2006 10:05 PM
weird suffix code... jackyandjoe Engine 1 07-01-2003 07:42 AM
sbc 350 4 bolt block suffix code help joakes Engine 1 10-24-2002 08:28 PM
