Suggestion-Shop Safety Section - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 02-05-2006, 08:37 PM
3100 Special's Avatar
Street Rod Dreamin'
Last journal entry: Last post project for a while
Thought it might be a good idea to add a section. I've see it on another site and have pulled some good tips out of it. Some seemingly innocent things can go bad if you don't think ahead.
I even have the first entry. Today's safety event:
I had forgotten about an incident that happened earlier today when I was posting the day’s efforts. Thought it worthy of sharing as both a funny (though not at the time) and a reminder that you should think ahead at the possible consequences when working in the shop. Or in my case today, the driveway…
Usually when I’m sanding or grinding on the panel, I’ve got on safety glasses, a paper mask and ear plugs.
So there I am, on my back with my safety glasses and I’ve marked my spots for the holes on the driver’s side 4 link bracket. No problem.
Tap the holes with a punch to make sure the drill bit doesn’t drift…check.
Squirt a little oil on the spots to aid in cutting…check.
Get my drill; make sure the cord is clear in case the drill catches (half inch drill, plenty of torque)…check.
Here we go, the bit starts it's job. No problem.
So what did I not mention above…no paper mask. Big stinking deal, right?
Wrong.
As the drill started biting and the shavings started dropping...that magical moment happened.
A nice, hot shaving dropped perfectly into my left nostril hole and fell perfectly (without touching the sides) to the ridge before going into my sinus cavity.
F-ing burn! The next immediate reaction was to release the trigger and raise up…pure reaction. In the brief moment, I had just enough sense to move my rapidly raising head to the side to avoid banging my gourd on the bottom of the frame.
Everything turned out cool. Blew a hole in a couple of tissues and everything was great. The piece of crud was free.
Forgot all about it until I was cleaning up this evening. Dang sure didn’t forget enough to not wear my mask the rest of the day though…
So was if funny? I have to admit, yea a little.
BUT, if that POS had dropped a bit further I might have been screwed.
Work safe folks!
Old 02-11-2006, 07:44 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Thumbs up
Glad you made out OK Shop Safety would be a good add on when Jons standing around doing nuthin{100% pure sarcasm there people }
There are 2 reasons my job would stop Some kind of injury or annoyance [usually something in my EYE ball] .
Or missing /lost tools.
R
"SlowRide66"
"Illegitimis non carborundum"
Old 02-19-2006, 01:30 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You have a good idea for a Shop Safety forum.....I think it would make a good sub-forum in the Garage and Tool forum.
Old 02-19-2006, 02:04 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Agreed. Although I don't think we have enough post volume now to justify another forum for shop safety.
I've bookmarked this thread, as this is a logical sub-division of the Garage-Tools forum down the line.
Old 02-19-2006, 04:07 PM
73oldsman's Avatar
Shop Safety... like not using cinderblock jack stands... or not soldering wires over your legs in the summer while wearing shorts... or not forgetting to drop your hood while striking a welder arc... or, well, you get the point. I could go on and on!
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 12:35 PM
center section measurement??? rlb Transmission - Rearend 2 01-30-2006 07:34 PM
shop air flow olsixrod Garage - Tools 2 04-06-2005 07:41 PM
neutral safety switch zipfactor Electrical 2 08-30-2003 07:58 PM
new help section + solutions to sloppy posting Jon Hotrodders' Lounge 5 07-03-2003 01:36 PM
