Suggestions on a brake/clutch pedal assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2002, 04:34 PM
AHotRod's Avatar
Lightbulb Suggestions on a brake/clutch pedal assembly
ok guys....I need a few of your ideas, I'm in need of a brake/clutch pedal assembly that I can reto into a '41 Willys coupe. I'm not sure wether or not I want to use a hydraulic clutch set up yet... do you have expierance in anything like this??? I guess I have done too many automatics...
Old 03-20-2002, 04:18 AM
Cool
How about using the pedals out of a GM S series truck. This is a hydralic clutch setup. You may not like the feel of the hydralic clutch in a performance vehicle. If that is the case try the pedals out of a Chevy full size truck. Most of the ones made up to 87 or so were manual clutch.
Old 03-21-2002, 06:23 PM
Post
Total Cost Involved in California has carried this in the past, and I have found them extreamly helpful when it comes to advise about their products. You might call them to ask if they have a pedal assembly that will work in your application and what is involved in the instalation.
Old 03-24-2002, 03:33 PM
New Member
Post
If your no where close to Cal. Gateway in Winfield Mo. carries a full line of Total Cost Involved products 636-566-6666. Ask for Jim Benny, hes the owner and he'll cut you a good deal and save you a bundle on shipping.
Old 03-24-2002, 05:03 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Post
If you are using a Ford tranny, use the clutch / brake pedal assembly out of an '83 - up Mustang. I salvaged the 5.0 H.O. motor, 4-speed trans. and clutch / brake pedal *** 'y. out of a '83 Mustang for my '27 Ford Roadster Pickup. The whole assembly unbolts and the cable clutch works great, especially with all the aftermarket heavy duty cables that are being made for 'stangs
Old 04-02-2002, 02:15 PM
F-1Rodder's Avatar
Post
You need to determine if you want to mount a hanging cluster from the firewall or bring it up through the floor. I don't like to see anything on the firewall that I don't have to put there, so I go through the floor. You can frequently modify the stock setup and mount an 8" vega vacuum canister behind it and it will all fit between the body and the frame rails. Take a look at some of the aftermarket units for sale. They are easy to copy and cost $200 less. Find the under floor units at swap meets. A dime a dozen.
