Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suggestions on a brake/clutch pedal assembly
Old 04-02-2002, 03:15 PM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
You need to determine if you want to mount a hanging cluster from the firewall or bring it up through the floor. I don't like to see anything on the firewall that I don't have to put there, so I go through the floor. You can frequently modify the stock setup and mount an 8" vega vacuum canister behind it and it will all fit between the body and the frame rails. Take a look at some of the aftermarket units for sale. They are easy to copy and cost $200 less. Find the under floor units at swap meets. A dime a dozen.
