Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suggestions of intake,cam and carb on 383 Stroker?
Old 07-02-2013, 08:17 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Originally Posted by haulingas View Post
I want ed to do that but the guy at the machine shop sad to freshin it up ie new crank bearings ect.so I I had to rip it down an go from there .was that a dumb move?
A freshen is never a bad idea, but did it need that? Some tests would have given you an idea, but that's a moot point now. You should learn as much as you can and be able to do rebuilds yourself, machine work aside. It'll come to you, just don't set the bar to high starting out.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
haulingas (07-02-2013)
