Suggestions of intake,cam and carb on 383 Stroker? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-02-2013, 09:08 PM
I guess I just wanted to be safe an replace some stuff in it.rather spend 400$ over trashing 2500$
  #17 (permalink)
Old 07-02-2013, 09:10 PM
Just wanted to be safe .rather spend 400$ over trashing 2500$
  #18 (permalink)
Old 07-02-2013, 09:11 PM
Canzus's Avatar
a red wool sock on his dinger
You appear to have missed the point completely...
_____________________________
Grumpy Fokker
  #19 (permalink)
Old 07-02-2013, 09:12 PM
Just wanted to be on the safe side
  #20 (permalink)
Old 07-02-2013, 09:16 PM
What was your point.cause your not being helpful at all.
  #21 (permalink)
Old 07-02-2013, 09:17 PM
I got your point if the motor was good why rip it down.I guess just to be sure everything is rite
  #22 (permalink)
Old 07-02-2013, 09:18 PM
vinniekq2's Avatar
A fresh engine as it was is probably a good place to start racing. Improvements can be made at anytime.When bracket racing,showing up regularly is the most important part
The Following User Says Thank You to vinniekq2 For This Useful Post:
haulingas (07-02-2013)
  #23 (permalink)
Old 07-02-2013, 09:24 PM
So you think I should just put the motor in as is an go from there.only things I had done were main bearings rod bearings an a new set of rings
  #24 (permalink)
Old 07-02-2013, 09:31 PM
vinniekq2's Avatar
buy a trailer and go racing
techinspector1 (07-02-2013)
  #25 (permalink)
Old 07-02-2013, 09:33 PM
Thanks for your help.very much appreciated.
  #26 (permalink)
Old 07-02-2013, 10:01 PM
techinspector1's Avatar
Wiki Edits: 326
Bingo!!!!!!! And don't forget, every one hundred pounds you can remove from the car makes it a tenth of a second quicker.
The Following User Says Thank You to techinspector1 For This Useful Post:
haulingas (07-03-2013)
  #27 (permalink)
Old 07-03-2013, 09:12 AM
i was thinking about going with harwood fiberglass doors an decklid.that should take some serious weight off dont you think.
  #28 (permalink)
Old 07-03-2013, 12:10 PM
Wiki Edits: 326
I would begin at the front of the car, removing anything and everything that is not necessary to the operation of the car, but still leaving it drag-race legal. Invest in some good-quality hole saws.
  #29 (permalink)
Old 07-03-2013, 02:01 PM
Everything in the car is gutted out front middle an rear.an what do you mean by whole saw.
  #30 (permalink)
Old 07-03-2013, 03:10 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Let me google that for you
Cut large holes in your car to remove extra weight.
Please help me pick a cam, intake, and carb- 383 Stroker Sixshooter45 Hotrodding Basics 82 05-23-2013 08:56 PM
383 stroker need cam suggestions. Thx. jaymarand Engine 1 06-23-2011 09:06 AM
383 Stroker Cam Suggestions mr_lwhite Engine 16 10-01-2010 06:50 PM
383 stroker built...now need cam suggestions Astrodokk Engine 7 01-31-2009 02:53 PM
383 intake carb suggestions stroked68 Engine 2 08-25-2006 11:37 AM
