Suggestions of intake,cam and carb on 383 Stroker? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2013, 05:22 PM
hello car gods.im in the making of building a 383 stroker for my drag car.its a 68 nova.im new to the drag racing world.ive built street motors before but a drag racing motor is a different kind of animal.any suggestion to what kind of intake,cam and carb to run.im open to anything.and any other kind of info would be much appreciated.
Old 07-02-2013, 06:02 PM
Banned
this will all depend on how much cash you have to throw at it.
Old 07-02-2013, 06:09 PM
vinniekq2's Avatar
how fast are you making the car? is the suspension already done? whats left to do?
Old 07-02-2013, 06:11 PM
vinniekq2's Avatar
maybe one of the mods can change your title for you? being lost has nothing to do with what you want?
Old 07-02-2013, 06:23 PM
i bought the car as a roller all suspension is done only thing left is motor an trans.i wanna try an be in the 10sec class.i got a ford 9in with 4:56 gears. the guy i bought the car off of put a ton of money into it.then i bought a 383 off my uncle it was setup to run on the street.and it didnt have what it took to run down the track as is.so i need to give it alought of love.
Old 07-02-2013, 06:46 PM
vinniekq2's Avatar
to get into the 10s with a 3600 pound car you will need 700 HP. I dont think a 383 will be the answer with out a turbo or super charger.probably 20,k away from engine/trans and hardware.
easiest way would be a N.A. 540
Old 07-02-2013, 07:46 PM
so what do you think i can do with what i got. ive seen cars with 355cid go in the 10"s or is there somthing im missing.
Old 07-02-2013, 07:56 PM
vinniekq2's Avatar
first;
how much drag racing experience do you have?
how well is this car set up? ie suspension/tires
that 355 car you saw? what was done to that car,is your car as good as that car and what did that other car weigh?
You can go fast with a 383,just need the right combination
you have to detail what you have
The Following User Says Thank You to vinniekq2 For This Useful Post:
haulingas (07-02-2013)
Old 07-02-2013, 08:50 PM
techinspector1's Avatar
Wiki Edits: 326
Guys don't normally jump into drag racing and go 10's right away.
I strongly suggest that you put the motor into the car and take it to the track the way it is. Once you have some time slips and are able to weigh the car with you in it, you will have a better idea of what to do to go faster.
The Following User Says Thank You to techinspector1 For This Useful Post:
Old 07-02-2013, 08:52 PM
I dont know much about the car I saw.but mine is fully gutted out it has 15/10/29 hoosiers on it.ford 9 inch with 456 gears.8 point cage fuel cell w/2 optimum battiers.half inch fuel line I think.traction bars the guy left all the msd hardware in it.get more info to you on that in a minute.be cool rad an fan.and a bunch more forget the name of the suspension components get back to you on that one to.line lock quater stick shifter with lockout.
Old 07-02-2013, 08:56 PM
I want ed to do that but the guy at the machine shop sad to freshin it up ie new crank bearings ect.so I I had to rip it down an go from there .was that a dumb move?
Old 07-02-2013, 09:17 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
A freshen is never a bad idea, but did it need that? Some tests would have given you an idea, but that's a moot point now. You should learn as much as you can and be able to do rebuilds yourself, machine work aside. It'll come to you, just don't set the bar to high starting out.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
Old 07-02-2013, 09:41 PM
Canzus's Avatar
a red wool sock on his dinger
Sounds like inexperience talking here. How was the oil pressure in the jewel your uncle gave you?
Oh, You didn't even run it did you...
Grumpy Fokker
Old 07-02-2013, 09:45 PM
oil pressure was fine motor ran good.just not track worthy.
Old 07-02-2013, 09:56 PM
Canzus's Avatar
What told you that? With no experience, it would have been fine...
But it's your money to waste...
_________________________________
Grumpy Fokker
Please help me pick a cam, intake, and carb- 383 Stroker Sixshooter45 Hotrodding Basics 82 05-23-2013 09:56 PM
383 stroker need cam suggestions. Thx. jaymarand Engine 1 06-23-2011 10:06 AM
383 Stroker Cam Suggestions mr_lwhite Engine 16 10-01-2010 07:50 PM
383 stroker built...now need cam suggestions Astrodokk Engine 7 01-31-2009 03:53 PM
383 intake carb suggestions stroked68 Engine 2 08-25-2006 12:37 PM
