suggestions on manual sheet metal hole puncher - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 11:07 PM
put up or shut up
I was looking at the Roper Whitney jr with 7 different sized dies. Hardened steel dies and I think they have replacement dies too. I dunno, sounds like it's worth the extra money. Other manual punches are around $30 but no replacement dies, one size hole, and not hardened steel. Can anyone vouch for the Roper Whitney Jr punch?
Old 01-26-2012, 09:47 AM
Joe G's Avatar
I use a 40 year old Roper Jr. hand punch almost everyday. I broke a die once, 15 years ago. Other than that it has been trouble free.
Old 01-26-2012, 12:27 PM
The different sized dies are VERY useful. You just can't believe how often you will find different holes that you can punch, wham, done.
Old 01-26-2012, 12:33 PM
Ron Covell has several videos about metal working, and repair. In one, he mentions using a step drill to drill out pin and rust holes with step drill to get clean edges, and then using this punch to make round disks sized to fill the hole the step drill made. Then TIG welding the disks in place, and metal finishing the repair.
Old 01-26-2012, 10:03 PM
put up or shut up
wow, that's a great idea!
Thanks for the responses. Will get one asap. In the meantime to make my HF air flange/hole punch tool better I just took a brand new cut off wheel and sliced it back right thru the opening to give me the option to punch the holes in a little more so I don't go burning an edge cause the darn cheapie punches holes to close to the edge. It's a great temporary fix.
Tin snip suggestions on cutting straight cut in sheet metal. MARTINSR Body - Exterior 24 11-22-2010 09:51 PM
Need Suggestions-Shaving Sidemarkers/Tacking in Sheet Metal A2brb Body - Exterior 3 09-17-2008 12:25 PM
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 08:48 AM
Hole in sheet metal stinger12 Garage - Tools 3 07-09-2007 05:16 PM
new sheet metal seaswirl Hotrodders' Lounge 2 09-06-2006 08:00 PM
