suggestions on master and power brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 12:37 PM
StudebakerDean
hi im looking for a suggestion on a brake setup for my pickup. i have disk all the way around, lincoln in the back and s10 in the front. should I go power brakes?, what kind of master/ power booster would work out ok for all disk brakes? id like to find a master / booster setup w/ pedal that frame mounts under the driver.
Old 07-11-2011, 08:31 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Companies such as Master Power Brakes, and many other hot rod part companies make universal under-floor pedal assemblies that should work fine for your application.
I would recommend power assist for 4 wheel disc brakes. The larger the diameter of the booster, the more assist you will get from it. If space is limited under the floor, you could use a dual diapraham booster unit. They come in 7" and 8" diameters and they work very well.
A 1" bore master cylinder for disc brakes would probably be a good bet for your application.
Andy
Master cyl. for drum brakes kreuzn1 Suspension - Brakes - Steering 6 04-26-2008 07:17 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
911 Brakes, Master Power Drum Brake Upgrades? frankenvette Suspension - Brakes - Steering 1 07-14-2004 08:04 PM
brakes new bleed evrything still no brakes master cylinder bad? IHAVECHEVYPARTS Suspension - Brakes - Steering 2 11-12-2002 08:09 PM
