Suggestions Needed, Speedo Cable Leaking Pic.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2013, 07:15 AM
My speedometer is leaking at the end of the hose where it attaches to the tranny, how can I stop this?
Old 06-11-2013, 07:51 AM
RWENUTS's Avatar
The seal inside the adaptor on the tranny is worn out or missing. Here's a link with some pics and info.
Help me get my TH350 speedo bullet to stop leaking?! - Team Camaro Tech
Old 06-11-2013, 08:32 AM
Ok thanks very helpful, Is that the o ring? I found one that fit around the speedo gear and put it in. Lets see what happens...
Old 06-11-2013, 08:56 AM
RWENUTS's Avatar
Like in the link. There's a big o-ring on the bullet (adaptor) and the small one inside that seals the gear.
Old 06-11-2013, 09:06 AM
Ok, is there a difference between a seal and an o ring on a 200r4, on a 700r4 from searches I have done they are different.....
Old 06-11-2013, 09:57 AM
RWENUTS's Avatar
Not sure but these guys could tell you.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Old 06-11-2013, 10:42 AM
Did a little more research they are different......
s6.photobucket.com/user/RODZSS/media/image_zpse178bec0.jpg.html][/URL]
I took the one out of my 700r4 a little different but fit, let's see if that works...
Speedo Cable Charlyg Transmission - Rearend 2 01-31-2013 10:11 AM
Speedo cable itsandre Transmission - Rearend 1 06-13-2011 09:44 PM
Speedo cable blues Vela Transmission - Rearend 12 08-31-2010 09:12 PM
Speedo cable issues IbanezPunk129 General Rodding Tech 4 08-29-2007 06:55 PM
speedo cable question.I need to know. Ken. P. Transmission - Rearend 3 04-25-2005 05:07 PM
