Suggestions for a rear axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2005, 08:05 AM
I have a 91 GMC Sonoma , 350 bored 30 over , 5 grand into motor , turbo 350 trans . Problem is , it has the stock rear end and need to put in a posi unit . Can anyone tell me what it has as OEM . Can i swap out a complete rear axle from another truck or am i best of to to just change the carrier with a 10 bolt posi . cost is a bit of an issue , The truck is driven mostly on the street , will see the track a few times a year . At 55 mph now it is turning 2800 rpms . Thanks for your help , Jim
Old 12-24-2005, 09:54 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
If you have the original glove box door still on the truck, there will be a list of RPO codes on a decal on the inside. Check the codes against this list it should tell you the diff size, gear ratio and posi or not.
http://www.freewebs.com/bubbabing/RPO_Codes.txt
Old 12-24-2005, 11:04 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The stock axle in there is a 7.5" ten bolt. It was adequate for the 4.3 V6 if you didn't stomp on it
Later S10s with the ZR2 offroad package had the 8.5" ten bolt and disc brakes. It'll bolt in, but there my be differences like driveshaft length, ujoint usage, etc, but its as direct as you'll get.
Rear axle positioning martinr Transmission - Rearend 4 12-28-2005 11:05 AM
REAR AXLE WIDTHS joegaddy Transmission - Rearend 6 12-17-2005 08:30 PM
Rear Axle Replacement MHenricks Transmission - Rearend 2 09-16-2002 08:06 PM
2000 Camaro Rear Axle Housing 4811 Transmission - Rearend 3 09-16-2002 11:18 AM
8" Ford rear Axle Ron Fowler Suspension - Brakes - Steering 7 04-26-2002 09:20 PM
