suggestions on steering arm construction - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2005, 07:19 PM
moparx's Avatar
New Member
i am almost done with the rack mounts for my 33 dodge project. the next phase will be to convert the spindles i am using from "rear" steer to "front" steer. any ideas for this ? bolt on or weld on arms ? what material should i use ? thanks in advance for any help you can provide !
Old 03-09-2005, 11:30 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Steering arms
Make them from cold rolled steel and bolt them on..Welding can be a bit of a problem on this application..Check with your local steel suppliers as some of them have the laser cutting machines that can cut the arms to a pattern that you provide..
OMT
Old 03-09-2005, 11:49 AM
cboy's Avatar
Last journal entry: Finished
Just a heads up that converting from rear to front steer can alter your Ackerman. So keep that in mind when designing (or buying) the new arms.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 03-09-2005, 07:38 PM
moparx's Avatar
New Member
thanks for the replys. i am taking great care to insure the geometry of this is correct. before i weld anything permanant, i am going to physically move the system throughout it's range to check bumpsteer & adjust as necessary. i have thought of fabbing up a different caliper mounting bracket, converting to GM pin mount calipers instead of the chrysler "sliders", and at the same time, incorporating the steering arms into this assembly. any thoughts on this idea ?
Name:	IM000947 (Small).JPG
ID:	4165   Click image for larger version
Name:	IM000949 (Small).JPG
ID:	4166   Click image for larger version
Name:	IM000950 (Small).JPG
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
power steering Paco Suspension - Brakes - Steering 9 10-31-2006 06:02 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
Aftermarket Ford power steering pump suggestions? LanceB Engine 2 11-18-2003 04:32 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
