Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suggestions on valve cover pcv valve baffle please!
Old 04-03-2005, 08:43 PM
67 Deuce 4 Me's Avatar
67 Deuce 4 Me 67 Deuce 4 Me is offline
Bowtie or Die!
Originally Posted by johnsongrass1
I use steel wool or green scotch bright pad loosely packed in. You can also cut out the baffle and make one of your own. Sounds like the baffle may be holding oil. You may need to drill a hole in the bottom of the baffle so oil can escape.
Thanks alot I will try that! .........Ed
