Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suggestions on valve cover pcv valve baffle please!
Old 04-04-2005, 12:00 AM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
There are also oil baffle grommets. Mr. Gasket makes them. Ther are designed for valve covers with no baffle. If you can't get the ones you have to work, you may want to ditch them all together and get the grommets. I am assuming you bought aluminum valve covers? If the are stamped steel then you may not be able to remove the baffle.
Royce
