-   -   Suggestions on valve cover pcv valve baffle please! (http://www.hotrodders.com/forum/suggestions-valve-cover-pcv-valve-baffle-please-60800.html)
67 Deuce 4 Me 04-03-2005 01:32 PM
I bought some valve covers for my sbc off E bay they look good but are a bit on the cheap side as far as quality goes. They came with a small oil baffle for the pcv valve looks like a small metal box. Ive notice oil is getting to the pcv valve when revved. I think the oil is getting sucked into my engine. I know this isn't normal. I read on another thread about using steel wool to keep the oil out. Is this the best thing to do? any other Ideas? Thanks .......Ed
johnsongrass1 04-03-2005 09:37 PM
I use steel wool or green scotch bright pad loosely packed in. You can also cut out the baffle and make one of your own. Sounds like the baffle may be holding oil. You may need to drill a hole in the bottom of the baffle so oil can escape.
67 Deuce 4 Me 04-03-2005 09:43 PM
Thanks alot I will try that! .........Ed
camaroman7d 04-04-2005 01:00 AM
There are also oil baffle grommets. Mr. Gasket makes them. Ther are designed for valve covers with no baffle. If you can't get the ones you have to work, you may want to ditch them all together and get the grommets. I am assuming you bought aluminum valve covers? If the are stamped steel then you may not be able to remove the baffle.
Royce
dawg 04-04-2005 06:45 PM
yes moroso sells a baffle that quite effective.
but youll have to drill 2 holes to mount it.
also you can try a short lentgth of hose or pipe to get the pvc valve out of the valve cover altoghether.
