Suggestions on valve cover pcv valve baffle please! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 12:32 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I bought some valve covers for my sbc off E bay they look good but are a bit on the cheap side as far as quality goes. They came with a small oil baffle for the pcv valve looks like a small metal box. Ive notice oil is getting to the pcv valve when revved. I think the oil is getting sucked into my engine. I know this isn't normal. I read on another thread about using steel wool to keep the oil out. Is this the best thing to do? any other Ideas? Thanks .......Ed
Old 04-03-2005, 08:37 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I use steel wool or green scotch bright pad loosely packed in. You can also cut out the baffle and make one of your own. Sounds like the baffle may be holding oil. You may need to drill a hole in the bottom of the baffle so oil can escape.
Old 04-03-2005, 08:43 PM
Bowtie or Die!
Thanks alot I will try that! .........Ed
Old 04-04-2005, 12:00 AM
camaroman7d's Avatar
There are also oil baffle grommets. Mr. Gasket makes them. Ther are designed for valve covers with no baffle. If you can't get the ones you have to work, you may want to ditch them all together and get the grommets. I am assuming you bought aluminum valve covers? If the are stamped steel then you may not be able to remove the baffle.
Royce
Old 04-04-2005, 05:45 PM
dawg's Avatar
NAVY VETERAN
yes moroso sells a baffle that quite effective.
but youll have to drill 2 holes to mount it.
also you can try a short lentgth of hose or pipe to get the pvc valve out of the valve cover altoghether.
pcv valve A/G WILLYS Engine 1 10-13-2004 08:59 PM
PCV Valve "rattling" colins72SS Introduce Yourself 6 08-06-2004 10:47 AM
I'm baffled....lol (valve cover q) killerformula Engine 6 07-05-2004 10:16 AM
PCV valve info question... Juicer Engine 3 11-06-2003 02:54 PM
Engine Valve Couver with baffle Buffed Engine 3 07-09-2003 11:24 AM
