Suicide door hinges
I am building a 50 chevy P/U I am almost finished with the 53 so i will be starting soon ,would like to get opinions and tips Before i start and do something stupid, <does any one have any experiance or suggestions for installing these doors .I want these before i chop the top but thats another story.
I did mine using stock components. Look at the build thread on my '48 Chev extended cab. Using an extra set of complete hinge pillars, move the driver's side to the back of the passenger door frame and vise versa for the other side. Cut the outer door skins away from the inner. NOT THE SAME AS I DID IN THE PICTURE!!! Cut the inner portion above the upper hinge and then down below the inner door handle and window crank. I had to redo that section after posting that picture. By cutting it like this the upper 1/4 of it stays stock so your door handle location and window crank does not change. Then swap the inner halves of the doors from one side to the other and weld back onto the outer skin.
It sounds confusing, but not once you see it. I have pictures of this that I will try to post in the next few days. |
I posted more pictures tonight of how I suicided my doors. Hope it helps.
| The Following 2 Users Say Thank You to Alaska Gasser For This Useful Post: | ||
496CHEVY3100 (01-14-2013), tech69 (01-14-2013) | ||
[QUOTE=Alaska Gasser;1634491]I posted more pictures tonight of how I suicided my doors. Hope it helps.[/QUOTE..Thanks for the pictures and information you are doing good work ,I was thinking of a different direction i located a panel with windows ,shorter than a surburban ,my thought was cut off rear af panel just behind rear door and graft rear of cab from pickup ,that would give me a pick uo with four full doors ,i have a 90- surburban for the frame ,so i can use full size bed,think might be less labor intensive , I would like to have diesel ,but will probably stay wiyh big block chevy thanks again for help,send more pictures as you progress..
| Does anyone know how to make a set of suicide door hinges? | Minitrucker | Body - Exterior | 6 | 01-26-2012 09:35 AM |
| Suicide Door Hinges | 46FORDPU | Body - Exterior | 23 | 11-24-2011 07:46 PM |
| Help with suicide door hinges | dwhip | Body - Exterior | 5 | 04-03-2007 01:47 PM |
| Where can i buy suicide door hinges for my 53 chevy truck? | engineart | Body - Exterior | 10 | 03-06-2006 02:02 PM |
| Suicide or regular door hinges | Cowtown Punk | Body - Exterior | 0 | 08-06-2003 06:03 PM |
