Suicide Doors for 1974 VW Bug? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2007, 08:13 AM
I've recently bought an older VW Bug, in good mechanical and electrical condition but with lousy paint and a stripped interior. I'd like to give it suicide doors. It has (like all VW Bugs of its age) exposed hinges, almost rectangular doors (not counting the top section) and is a two-door, so I don't have to worry as much about a weak center post. I'd rather use the current hinges if I can, rather than spending $200-1500 for aftermarket hinges. I'm an OK welder, but I've never tried anything quite like this before. Any advice?
Stray Catalyst
One other thing - should I try to use the latches that are already on it, or look for a different type of latch? I'd like to keep it fairly stock looking, but I expect I can interface the current doorhandles with whichever latch I get.
Old 04-05-2007, 08:25 AM
Shabby chic sheet metalshaper
You might check out:
www.volksrods.com
www.runtrod.com
www.franklinsvwwerks.com
One of the problems I've seen with suicide doors on Bugs is that if you do not use the right hinge geometry, the door hits the body before it is all the way open. But if you are using the stock hinges, that should not be a problem, because they have the pivot point outside of the door.
John
Old 04-05-2007, 09:14 AM
I did suicide doors on a Bug once, used 55 Ford F-100 hinges, worked like a charm. But I have to tell you, it is a big project. Using the stock hinges would be a lot easier, that is for sure.
Old 04-05-2007, 09:28 AM
I don't suppose you have any pictures of your project, either during the build or after completion? I'd love to see details of how you did this.
Stray Catalyst
Old 02-04-2009, 03:35 PM
suicide doors
i've heard that you use the left side door hinges on the right side of the bug door jamb. then visa versa.
Old 02-04-2009, 04:35 PM
Resurrecting a 2 and a half year old thread. This car is either finished, or junked.
anyone need a VW bug? hatebreed Hotrodders' Lounge 25 11-26-2005 02:23 PM
suicide rear doors over wheel well? flamedfordbronco Body - Exterior 8 02-20-2004 10:11 AM
4dr suicide doors along diagonal? Nanook Body - Exterior 0 01-09-2004 11:26 AM
Suicide Doors 50Windsor Body - Exterior 1 07-17-2003 08:31 AM
Suicide doors - first post 62slantsix Body - Exterior 4 03-08-2003 11:26 PM
