Suicide doors on a Comet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2006, 02:47 AM
I am thinking about suiciding the rear doors of a 4 door, 1960 Comet. It seems like most people suicide doors that are pretty much rectangluar in shape, but the rear door of the Comet has the curve for the back tire built into it. Is this possible to do? I have the metal working and welding skills, but I wanted to know if there were problems trying to move the hinges onto the back of the door where the curve is located. For example, will the door bind when it opens?
I have attached an image to show the area I'm talking about. This isn't the actual car, but has the same door design.
Thanks,
PeterM
Name:	Suicide door problem.jpg
Old 03-20-2006, 08:23 PM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
Anything can be done, you might go over it 20 times to get it right but this is what its all about. Go for it, and i think you will have something to be really proud of. If everything was easy everyone would be building these cars. I think this would be a great look on this car, and i dont think i have ever seen one like it. Take your time and think it out, but at least get started and it will fall into place.If you dont try it you will never know what you could of had. Good luck and i hope you see this idea through to the end. Im behind you all the way on this, and im sure there are plenty of guys here who will try to help you solve any problems, as thats what this group is all about.
Old 03-21-2006, 12:46 AM
Mrwood,
Point well taken. Sometimes thinking too much is what stops you from trying anything. At the very least, I should grab a couple of buddies, pull one of the rear doors off, and try and move the door around to see what happens when you open it backwards. I might need to fabricate some hinges that swing out, but I won't know until I try.
Thanks,
PeterM
Old 03-21-2006, 09:13 AM
As long as you keep the hinges on the part of the door that's near vertical (or seems that way in the pictures) I can't really foresee any issues. You should try and keep the pivot point on the hinge as close to the outside of the body as possible. Also the further apart you can space the hinges the better. Unfortunately that's going to be tough in your case. It's also hard to tell though from the picture how much the panel curves in above the bodyline by the doorhandle.
Old 03-21-2006, 09:47 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
like you said, most doors this is done to are mostly square, and that fact allows you to put alot of space between the hinges, preventing them from twisting to far.
that creats a small problem on your car, but not one that cant be overcome
my recomendation would be to build your hinges extra strong, and use 3 pivot points on each door instead of 2. that way even tho the forces of the door have more leverage on the hinges, your hinges have the extra material to make up for it also
Old 03-21-2006, 10:19 AM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
If you want to put a lot of work into this I would suggest making it a two door. Weld those babies shut -new glass and bang new look sitting still or driving. Admittedly I have not done a car door hanging, my 29 Tudor has suicide doors, I bought it that way, I have hung a lot of house doors and the hinges have to be parallel. As lowrollerchevy suggests, two, extra heavy. Because of the curve they could easily get out of alignment using three. I am thinking if they are both above the curve that might be easier to make the door function. LOL Jack
Suicide doors in my area testlightST Body - Exterior 5 01-02-2005 12:35 PM
suicide rear doors over wheel well? flamedfordbronco Body - Exterior 8 02-20-2004 09:11 AM
4dr suicide doors along diagonal? Nanook Body - Exterior 0 01-09-2004 10:26 AM
Suicide Doors 50Windsor Body - Exterior 1 07-17-2003 07:31 AM
Suicide doors - first post 62slantsix Body - Exterior 4 03-08-2003 10:26 PM
