Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suicide Front End
Old 02-16-2012, 08:01 AM
unix unix is offline
Originally Posted by graydog
Type in "Suicide Front End" in the search box at the top of this page and read some of the posts on the subject.
Most of these set ups consist of a spring pearch, spring, front axel with assicoated hardware for brakes and stability. You can buy a complete set up less the pearch from resources such as speedway motors. Look there, the front of the frame will require a frame section or modification of a cross member to be welded at the front or end of the frame. That pretty much sums it up.
Suicide Front End simply means the first point of contact in a head on crash, that takes out the front suspension.
