Originally Posted by techron
What was the point you were making?? No offence is intended. A squared frame? Look at your pic 5
I have a reversed corvair steering box on my gasser just like in your pic. The difference is that I mounted the box on the frame so the pitman arm was excatly at the center position axactly right along side of the radius rod mount bolts. Then I
positioned the foreward steering link exactly as long as the rods are. No bump steer. This is Imprtant on a gasser going through the quarter as I had enough to think about, 11 seconds at 128 and shifting. Holding the steering wheel straight was a no brainer, just trust castor when pulling whelllies on a gasser.
This one has no bump steer either..
