Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suicide front end
  #57 (permalink)
Old 12-27-2012, 05:53 AM
gearheadslife gearheadslife is offline
Banned
man, most of the cars with spindles that got hit in the nose, or bumped a curb. and bent the tie rod arm on the spindle are running around with ankman totally f up
yes you should address it, if you can.. if not.. you "might" get tire wear.. my bet is the tires will dry rot before you wear them ..
