Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suicide front end
  #59 (permalink)
Old 12-27-2012, 09:09 AM
MARTINSR MARTINSR is online now
Originally Posted by gearheadslife View Post
man, most of the cars with spindles that got hit in the nose, or bumped a curb. and bent the tie rod arm on the spindle are running around with ankman totally f up
yes you should address it, if you can.. if not.. you "might" get tire wear.. my bet is the tires will dry rot before you wear them ..
A little bend in the steering arm doesn't come anywhere close, not even in the same ball park, or city the ball park is in with what we are talking about. It's like comparing a rock chip on the hood of your paint job "ruining" it to pouring two gallons of Aircraft stripper over it.
