Suicide Front End - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2012, 04:52 PM
Suicide Front End
Can someone help me. New to the whole hot rod thing and i have a 31 model a sedan. Wanna put a suicide front end on it but dont know where to start. I guess what i am asking is if people can give me a list of parts and some direction.
Old 02-15-2012, 10:07 PM
graydog's Avatar
Suicide Front End
Type in "Suicide Front End" in the search box at the top of this page and read some of the posts on the subject.
Old 02-16-2012, 07:01 AM
PATH=$PATH\:/usr/local/bin ; e
Most of these set ups consist of a spring pearch, spring, front axel with assicoated hardware for brakes and stability. You can buy a complete set up less the pearch from resources such as speedway motors. Look there, the front of the frame will require a frame section or modification of a cross member to be welded at the front or end of the frame. That pretty much sums it up.
Suicide Front End simply means the first point of contact in a head on crash, that takes out the front suspension.
Old 02-16-2012, 08:04 AM
Some additional information is needed. Are you going to run fenders? If not to put that type of suspension on an A frame
you will have to cut the frame off at the front of the front cross member. thus removing the frame horns.
do you want the spring behind the axel? tie rod behind or in front of the axel? what steering box are you going to use? what engine/trans ?
Lots of questions
good luck on your project. how about some pictures?
Terry
Old 03-13-2012, 08:20 PM
i dont know how to post pics on here. i found one on pete and jakes that i like. just dont know what to do with it. i do not want fenders at all. i wanna lower it and hope to channel the rear end and get a solid rear end instead of the independent i have in the back.
Old 03-14-2012, 06:22 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
My buddy used a Speedway front end on his model A and had it chromed
Old 03-18-2012, 09:41 PM
that is how i want mine to look. what kind of rear end did he use?
Old 03-19-2012, 06:39 AM
Arrowhead's Avatar
Wiki Edits: 5
He used a Heidts IRS - very expensive.
suicide front end on 55 chevy gasser???? new_rat_rodder Suspension - Brakes - Steering 7 02-09-2011 10:58 PM
Suicide front perch 61bone Suspension - Brakes - Steering 7 07-14-2005 06:56 AM
How to old school a suicide front end on a 32' Ford teched Hotrodders' Lounge 2 09-22-2004 08:07 AM
suicide front-end????????? DollarDan_RoadRage Suspension - Brakes - Steering 8 08-11-2004 09:36 PM
Suicide front end on the bucket Barz51 Suspension - Brakes - Steering 6 03-17-2004 05:10 PM
