And of course guys you can put the tie rod out front and also have proper akermann, they can co-exist. As long at the steering arms are bent out wide enough, tucked into the wheel unfortunately. As long as the line between the tie rod end pivot point and the center of the rear end housing goes thru the king pins.
Brian |
Thank God someone didn't read them book's..
Keep reading them book's guy's...
![]() I'm done here.. |
![]() Brian |
I understand but then after it was done on paper it showed that it would. It isn't like the bee which on paper is isn't suppose to fly. The helicopter on paper does fly, the lift created by the rotor (which is shaped like a wing) over comes the weight of the body. They weren't able to pull it off until it was done on paper.
Brian |
more akerman.
My brother used to race go-karts, When the geometry was wrong you could actually feel it turns. He let me drive his fast one a couple of times, He used a triangle plate with the front tierod, the left tie rod hooked to the right side of the triangle, and visa-versa, that put the right akerman back in, With the backwards akerman, and bigger tires than on a lot of T buckets, when you hit a bump the tire with the most traction decides which way you go, and I have had one car I built cross the white line on a bumpy turn with traffic coming towards me.
I don't spend much time at all on forums anymore..
Now I remember why. DeeW,my point to you was,if you're building the frame from scratch, follow the basic 4" dropped axle spring on top,stamped crossmember, cross steer,and you will have a solid chassis. Also be sure to use tie rod ends on your tie rods,and not heim joints. Forged steering arms. Don't fall for the cheap prices online,buy American and you will only need to buy it once. |
man, most of the cars with spindles that got hit in the nose, or bumped a curb. and bent the tie rod arm on the spindle are running around with ankman totally f up
yes you should address it, if you can.. if not.. you "might" get tire wear.. my bet is the tires will dry rot before you wear them .. |
Never Mind... ![]() ![]()
![]() Brian |
One Question for the chassis engineer's here..
Get under a factory Mustang II With the rack in the front.. Try to draw these lines and see where they end up on a Mustang II.. Why your at it.. Get under a 2000 Yukon and try doing the same thing... Let see what your lines will Look like.. ![]() And case you don't know it.. You can't make these lines meet at the rear.. since You guy's got it all figured out,, you need to tell me why these cars was built this way.. ![]() Must be why they started putting the rack's in the back...
| Suicide Front End | Txfan07 | Suspension - Brakes - Steering | 7 | 03-19-2012 06:39 AM |
| How to make an Old School Suicide Front End | teched | Suspension - Brakes - Steering | 3 | 09-26-2004 05:26 AM |
| How to old school a suicide front end on a 32' Ford | teched | Hotrodders' Lounge | 2 | 09-22-2004 08:07 AM |
| suicide front-end????????? | DollarDan_RoadRage | Suspension - Brakes - Steering | 8 | 08-11-2004 09:36 PM |
| Suicide front end on the bucket | Barz51 | Suspension - Brakes - Steering | 6 | 03-17-2004 05:10 PM |
