suicide front-end????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2004, 12:31 AM
New Member
does any one know what a suicide front-end is???????????????
Old 08-11-2004, 12:40 AM
63' Falcon Gasser's Avatar
New Member
Im almost positive it's where the whole front end of the body flips forward as a whole. Fenders, hood, grille, everything. Gassers used em a lot so they could work on the engine easier.
-Tyler
Old 08-11-2004, 12:48 AM
New Member
hummmm i thought it had some thing to do with 37-39 style strate axles. some thing they did to make them lower.
Old 08-11-2004, 12:52 AM
New Member
Probably but I know a suicide front end is when the hodd,grille, and fenders fold forward to reveal the whole engine compartment.
-Tyler
Old 08-11-2004, 01:11 AM
willys36@aol.com's Avatar
Wiki Edits: 21
That refers to how hot rodders mount early ford front axles, especially on T-buckets and hot roadsters. They eliminate the front axle x-member and mount the spring to the frame with a little plate that is attached to the front of the frame. Thus the entire front suspension is hanging out in front of the car.
Like this;
Old 08-11-2004, 11:31 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Funny how such a common term is lost in a generation. It was over 50 years ago that I helped a friend build a suicide. This was on, of all things, a tube frame sports car with Allard-style swing axles.
Old 08-11-2004, 12:41 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
A center mount spring perch is the only place that the front end assm. is mounted solid, thus called a suicide mount.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 08-11-2004, 10:29 PM
New Member
ooooo so it is when the axle is in font of every thing i seee. that would let the car sit as low as you wonted.
so i have a new qestion???? how can i lower a 37 ford and keep the stock font end??????
Old 08-11-2004, 10:36 PM
troy-curt's Avatar
Use a dropped axle.
Troy
