summit angle plug heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2009, 05:11 PM
Just picked up some heads at the4 last minute... came across them and figured i would give them a try.
they are supposed summit heads. They have enlarged valves - 2.05 / 1.6
square port exhaust...
number on them is
ses-3-60-03-001
i am trying to make sure these will work with my headers. These are *****en heads. Screw in studs with lifter guides.... the massive valves and a smaller chamber then the other heads i was going to use....
let me know if you know what these are or if you have some assumptions...
Thanks.
Old 03-20-2009, 05:38 PM
summit tells me they are discontinued and that is all they know....
Old 03-20-2009, 06:06 PM
techinspector1's Avatar
Wiki Edits: 326
Angle plug heads can present more of a header fitment problem than straight plug heads.
Old 03-20-2009, 06:21 PM
called summit rather then chat....
they say they are world products sportsman 200's
now i'm gonna go learn about these!
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 01:48 PM
Axle Housing Install - Pinion Angle Help leejoy Transmission - Rearend 3 01-08-2007 02:06 PM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
Camel Hump Heads Thermactor Plug? Cole Engine 7 12-13-2004 01:42 PM
