Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Summit Engine stand
Old 10-14-2006, 02:53 PM
scholman scholman is offline
428HO,
From the looks of your pictures the place that needs to be "beefed" up is the rotating face plate.
I used 1 inch plate and then drilled holes where I needed them. Then threaded the holes so I did not need the nuts like you are using.
Good Luck
Scholman
