Summit Harmonic Balancer on a 5.0 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2013, 09:01 PM
I just installed a Summit balancer but I am not sure I got it right.
Before installed I heated it in the oven. It slid on and then I seated it with a few light taps.
The back side of the dampner is 1/8" away from the timing chain cover.
Looking at the front, there is still some space between the front of the crank and the surface of the dampner. Should it be flush?
I attached a picture. Should it go back further? I dont know if it would bottom out before it hits the timing chain cover.
I attached a couple of pictures. Am I okay or soomething wrong?
The timing chain cover is from a 302.
ID:	71990   Click image for larger version
Old 03-03-2013, 09:10 PM
BOBCRMAN@aol.com's Avatar
Looks alright. Crank is not designed to be flush with hub.
Harmonic Balancer 65malibuSS Engine 1 11-29-2009 06:41 AM
Summit Harmonic Damper SBC cowbay Engine 3 06-01-2008 03:39 PM
Harmonic Balancer help sexypizzaman Engine 4 02-11-2008 05:21 PM
harmonic balancer desktop Engine 3 07-12-2006 07:44 AM
Jeg's/Summit Harmonic Balancer radracer43 Engine 1 09-06-2005 07:46 AM
