Summit Harmonic Damper SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2008, 12:27 PM
cowbay's Avatar
I am building a 383 SBC stroker. This car will be street most of the time with a trip to the track 8-10 times a years. Horsepower for the car should be around 450HP I was looking at the summit harmonic dampers. Has anyone heard anything good or bad?
Brand: Summit
Product Line: Summit Harmonic Dampers
Part Type: Harmonic Balancers
Part Number: SUM-B64265
Engine Balance: Internal
Balance Style: Neutral
Safety Rating: SFI 18.1
Degree Markings: Yes
Degree Marking Range: 60 BTDC to 0 TDC
Outside Diameter (in): 6.610 in.
Harmonic Balancer Material: Steel
Harmonic Balancer Construction: Elastomer
Harmonic Balancer Finish: Natural clearcoated
Mounting Hardware Included: No
Quantity: Sold individually.
Notes: Bolt-on counterweight sold separately, timing pointer available separately. Weight is 10.37 lbs.
Harmonic Balancer, Internal Balance, Steel, Clearcoated, Chevy, Small Block, Each
Old 06-01-2008, 02:20 PM
automotive breath's Avatar
That Summit dampener is manufactured by Cyco Systems Corporation
in Australia. It's a high quality part at a good price. I have used then
for years to 8000 RPM with no problems to date.
Old 06-01-2008, 02:34 PM
406 bug's Avatar
9.82 @ 139mph
Try c-4265 its a lot cheaper and has all the same features. I have one and am very pleased with the quality. I think it is manufactured in Australia.
Old 06-01-2008, 02:39 PM
cowbay's Avatar
It is good to hear that about this product. That is what I wanted to know because Summit has a name brand make their specific item. Looking on the internet I see that this is a very focused company that one of their main specialties is harmonic dampers. So sounds like this may be the way to go
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
Summit Ignition System vs MSD Harley Monster Engine 4 07-22-2007 04:09 PM
350 marine harmonic damper goof ball Engine 3 12-19-2006 07:04 PM
GEAR DRIVE = DAMPER PROBLEM bullheimer Engine 5 07-06-2006 12:09 PM
350 damper and snout questions Vortech 4.3 Engine 3 03-05-2006 08:03 AM
