Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - summit/jegs in house ring and pinion
Old 07-18-2002, 09:50 AM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is online now
Post
I beleive the only difference is that the Richmond sets are forged and then nitrided after machining, this is the ultimate from a strength and durability point of view. The no-name brand versions are heat treated castings and are the same as the factory original gears. Unless you are drag racing all the time and run a high horsepower engine(400+HP) with a standard trans the lower cost versions work well if set up properly.
— Han Solo
