Summit mini starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2011, 12:43 PM
Dan
Summit mini starter
anyone has any problems with a summit mini starter not disengaging from the flywheel?
Old 12-09-2011, 01:52 PM
No. This could be either a solenoid failure to retract the gear when the coil current is cut off, this is a return spring function inside the solenoid, could be spring or plunger problem.
But most likely it's a shim issue with the starter mount where the starter pinion and ring gear lack enough clearance resulting in the pinion getting stuck in the ring gear's teeth. I know a lot of these starter's claim shimming isn't required, but this problem still happens. Parts store or GM parts counters usually have one piece shims stock.
The last thing is some starter put the pinion too far into the ring gear and they essentially get caught behind the ring, there should be shim that looks like a ring on the starters pinion shaft to adjust that.
Bogie
Old 12-09-2011, 02:32 PM
Are you by chance trying to run a remote solenoid?
changed from oem starter to high tork mini starter , wires .? don wills Electrical 2 09-04-2010 06:34 PM
Mini starter JohnBer Engine 6 03-17-2010 11:41 AM
Which Mini Starter to buy? mkjarobinson Engine 34 03-06-2009 11:04 AM
Summit SUM-820323-M Starter Jake_Dragon Engine 2 02-10-2009 08:47 PM
mini starter notsure Engine 4 09-21-2008 06:56 PM
