Summit Piston Rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2005, 12:26 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Summit Piston Rings
Hey guys, I am currently putting together a 289 Ford....dont have a car for it yet, but can build the engine now so I am. I am looking at running some speed pro hypereutectic pistons, as far as rings go would summit cast rings be ok? Or should I stay away from them? Heres what I have planned as of right now.
.030 over
Speed Pro Hypereutectic pistons
Crank .010/.010
Stock rods
Summit Cast Rings
C5AE Heads
Comp Cams XE262H kit includes springs,lifters,timing chain, retainers etc
Havent decided about an intake or carb yet. I'd appreciate any advice. Hope I gave enough info. Thanks in advance.
Old 09-06-2005, 02:09 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
A Holley 600 and an Edebrock Perf or Perf/Rpm.
Old 09-06-2005, 02:21 PM
Thanks Bracketeer.
Old 09-06-2005, 06:20 PM
Wiki Edits: 49
Never bought a bad part from Summit Racing. I wouldn't hesitate to use their rings.
Old 09-06-2005, 07:33 PM
Thank you centerline, I went ahead and ordered them. Thanks to you 2 who helped out.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
