ok, so lets do some math....You can get SPI (an exellent epoxy primer) for somewhere around 150.00 (,could be 200.00 I'll have to double check) thats with the activator, thats a 1:1 mix ratio,so you actually get 2 sprayable gallons of primer.and not need a 2k you can use the epoxy in place of a 2k ,(not something you can do with most other E primers) so figure a gal for the metal and a gal for covering the filler and building for blocking..You'll use it all..mabee more...
Whats the mix ratio for the Sumit epoxy and how much does it cost for the primer and the activator?? it would be interesting to know how much savings there actually is between the two and if its worth it...
