Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - summit primers
Thread: summit primers
  #23 (permalink)
Old 01-15-2013, 08:03 PM
carolinacustoms's Avatar
carolinacustoms carolinacustoms is offline
Automotive Extraordinaire
I will not come back after this Kelly. I am afraid I will appear to be overly defensive. I knew Mike (deadbodyman) had done this. When I ordered the material I asked Barry at SPI what he thought about this and he advised the epoxy is tougher than the 2k primer and said I could do it without fear. He would have not approved a questionable proceedure.
John I apologize for the bad wording on my part. I didn't mean to sound like I thought you had done something wrong. I think the epoxy would be a better choice if the bodywork was done well and time wasn't an issue. And I am sure you were fine to do so if Barry said you were. I generally don't use high build unless its a production type job where time is an issue. Again I apologize for the misunderstanding. I was actually agreeing with you earlier post where you said no one was suggesting epoxy replaces a good high build. Good being the key word.
Kelly
