summit primers - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-16-2013, 08:51 AM
Originally Posted by deadbodyman View Post
Whats the mix ratio for the Sumit epoxy and how much does it cost for the primer and the activator?? it would be interesting to know how much savings there actually is between the two and if its worth it...
I just paid $99.85 for a gallon of both Summit's epoxy primer and catalyst (2 mixed gallons, 1:1), which includes shipping ($9.95) and it was delivered overnight via UPS since I only live a state away.
SPI is around $120 for the same amount of product. I ordered some last year, but I can't remember the shipping.
  #32 (permalink)
Old 01-16-2013, 04:31 PM
SPI's shipping would have been free. $110 Summit primer shipped vs. $120 SPI epoxy primer shipped. Plus tech support all day, every day, from the brass himself. This one is a total no-brainer.
  #33 (permalink)
Old 01-16-2013, 08:20 PM
It was less than $100 Summit shipped. So that's $20 cheaper. I really don't need tech support for epoxy primer, so you're right, it is a no-brainer.
  #34 (permalink)
Old 01-16-2013, 08:55 PM
nothing wrong with liking a different kind of product.
but if you try to compare the Quality and support of a product sold by Summit(some say made by Kirker)then yes it is a no brainier that you will continue to be questioned on that.
no matter if its Epoxy or base ,clear or whatever sometimes we all need help!
Best of luck
Travis
  #35 (permalink)
Old 01-16-2013, 09:09 PM
I forgot you guys get dogmatic about such things as these and are intensely brand-loyal...I'll leave you to it then. Cheers!
  #36 (permalink)
Old 01-16-2013, 10:22 PM
carolinacustoms's Avatar
Automotive Extraordinaire
No one is trying to be offensive about anything. Someone asked for advice and several of us have tried to offer some attempting to be helpful. I understand that sometimes, cheaper products have to be used, especially in a Production environment. However, I try to use the best product possible at all times, so I avoid the "cheap" jobs because I don't want my name and reputation ruined because someone did not want to buy quality materials or pay for a quality repair. Like I said earlier I have no experience with Summit products so I will not comment good or bad, for or against them. I have on the other hand used the best that Dupont, PPG, and MS have to offer and find that SPI epoxy, 2K, high build, and Clears are superior to them in quality, usability, and price. I agree there are cheaper products than SPI and do not argue that point, but I will say that cheaper is not always better. Would you take a car that you had 400 hours of work in to Maaco to get a paint job because they can spray it for $500 instead of spending more to do it yourself with a quality paint? I don't think anyone would, but maybe I am wrong. I will personally and publicly apologize to you and anyone else on this forum if I have said anything to offend anyone. If I have it was completely unintentional. I would never intentionally make a comment that I felt was attacking or offensive, but I also understand that my wording is sometimes not the best. I only hope to help someone with my experience ( and there are a LOT of people on here with more knowledge and experience than I have) and personal experiences. I wish you the best in your projects whatever line of products you use now or chose to use in the future.
Kelly
The Following 2 Users Say Thank You to carolinacustoms For This Useful Post:
cyclopsblown34 (01-17-2013), John long (01-16-2013)
  #37 (permalink)
Old 01-17-2013, 05:27 AM
deadbodyman's Avatar
Wiki Edits: 11
How much was the SPI by the qt ,John and the activator also...
I'm going to take a guess that the Summit activatior is the smae price as the primer ,so 32.00 and 2 sprayable qts ???
If your doing a whole car that wont be enough...well, it depends on how big it is...
I've heard guys using the Summit epoxy really like it..
  #38 (permalink)
Old 01-17-2013, 05:44 AM
Wiki Edits: 11
Originally Posted by 69 widetrack View Post
Mike, I just tried some SPI Epoxy...and abused it...I did a bunch of 18" X 18" test panels...on one, I ground a spot about 10" X 10" with a 24 grit disc buzzed the 18" X 18" panel with 80 grit on my DA, (not a real harsh buzz but enough to rough up the edges for mechanical adhesion)...I applied 2 wet coats with a 1.8 tip (not puddling wet but much heavier than I normally would), allowed about 2 hours flash at about 70 degrees between coats and let it sit for about a week to cure....I blocked out the primer....it seemed to take care of the scratches...I painted it about 10 days ago and it still looks good...didn't sink or die back....(A disclaimer here, I don't recommend this or would I ever do it on a customer's vehicle or anything I really cared about...it was a test panel and wanted to see how far I could push it.)
Mike, when you sprayed your 8 coats of epoxy to cover 36 grit scratches, was it sprayed fairly lightly or heavy? The reason I'm asking is because I seem to have more or less filled 24 grit scratches with 2 coats being sprayed leaning on the wet side. Did I abuse the product...you bet I did...will the test panel die back or sink...it should, because after sanding there isn't enough product to evenly fill the profile left with the grinding disc. I will say I am impressed with what I've seen so far.
Ray
I sprayed two VEEERY wet coats and let it flash for two hrs ,It took the whole day to get the primer on then it took about a week to cure..one good way to know if its cured is to DA sand it ,if the paper clogs with little balls its not ready yet...Like you, I dont recomend doing this I was just pushing it to its limits ,I could never recommend something I didnt have complete faith in...
and I'm not easily impressed, I've used about every epoxy that matters and nothing else does what this does,Its not only impressive, its my new standard to measure all others by.if another product comes along thats better or if the price of it gets outragous ,i'll switch but I really dont see that happening anytime soon...
The Following User Says Thank You to deadbodyman For This Useful Post:
John long (01-17-2013)
  #39 (permalink)
Old 01-17-2013, 06:00 AM
Wiki Edits: 11
Your so right we are VERY brand loyal and theres a good reason for it ...
when you do this for a living every dollar counts and we want the very best we can afford so we try many brands over the yrs untill we find the right one,in that quest we also find a lot of crap... we also have reps come by and give us stuff to try...So when we finally find something that works better than expected or in the case of the SPI epoxy head & shoulders above the rest we just HAVE to let the other pros know what we found....It took me thirty years to find the best epoxy and I've used some real crap and made a lot of bad mistakes I learnd from ....Thers no need for you or anyone else to learn the hard leasons if we share our knowlage.
OK so since I've never used Sumit ,how many guys posting have and how many have used both SPI and Sumit ???? What do you guys think of the two...
  #40 (permalink)
Old 01-17-2013, 06:05 AM
Wiki Edits: 11
This here is what I was just talking about ...so how do the two compare???? other than the price....like sanding ,building etc....it was said sumit was thicker ,does it go farther?
Sorry for all the posts I'm still catching up from yesterday...
  #41 (permalink)
Old 01-17-2013, 06:07 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
I just got my shipment of Summit epoxy primer yesterday an used some of it.I used a brush ot paint the channels where the t-top weather stripping is glued in. I'm sure its good stuff but be aware that what Summit says is gray is a very,very dark gray.
  #42 (permalink)
Old 01-17-2013, 08:13 AM
33.75/qt for both paint and catalyst
John
  #43 (permalink)
Old 01-17-2013, 08:18 AM
By the way guys, SPI's price sheet shows their gallons of epoxy and catalyst are 86.10 each.....
  #44 (permalink)
Old 01-17-2013, 09:34 AM
Faith - Respect - Trust
Thanks Mike, I also read in another post that you wrote that your 36 grit scratches where over top of filler...that explained why you would have sprayed 8 coats as filler is porous, should and will soak up some of the primer where as metal won't. I was just wondering and trying to explain to anyone reading these posts as to why I could fill 24 grit scratches with 2 wet coats and you used more. Different tests but still very interesting results.
I also know what you mean by uncured primer sanding in little balls...it did take a week of cure time for this primer (when abused as I did) to have respectable sanding qualities...being an Epoxy, it should be expected.
I'm not easily impressed either...for what I do now, price is rarely an issue, it's more about quality...Customers, as usual, complain about the price of material and labor to do quality paint work and body work...When I explain to them that the engine in their car often cost more than the paint and body job and they haven't even paid to put the motor in and get it running properly yet...they more readily stop, listen and understand. When I find a product that works and does what is broadcasted by the manufacturer tech sheets and on top of it all, price is user friendly, it's a no brainer. My experience with SPI is limited, I haven't used it much at all, but, from what I see so far, I will. I mentioned on another thread that I have 2 jobs that I'm finishing up and am getting close to the painting stage....(Old Fords, a model A and a model T) so black is the color of the day. I will order SPI, epoxy, black base and clear to complete these jobs.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
  #45 (permalink)
Old 01-17-2013, 11:16 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Holy neck!I haven't been notified since the first reply.Ive been using summits 2k primer surfacer for everything I've attempted.Its pretty good for what it is&now its on sale for only 38 fills ok I just orderd a bunch to have but I want something that fills really well to help with my lack of experience.I've been blocking my primer with 400 before paint. I use a durablock I just ordered 1 of their memory blocks.Ill see how that works.
Best Primers ddailey Body - Exterior 3 02-09-2012 11:28 PM
primers eleconone Body - Exterior 3 01-08-2012 06:55 PM
primers kkinney Body - Exterior 9 03-09-2007 09:33 PM
different primers burninrubbah617 Body - Exterior 4 01-15-2006 08:14 PM
Primers? Sleezie Body - Exterior 2 03-31-2005 12:33 PM
