Summit Racing 2k urethane primer surfacer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2010, 12:50 PM
Tomlowe523's Avatar
Has anyone used this before? If not could you take a guesstimate on the quality of it. I'm also curious about their clear, I put links to both at the bottom. Thanks so much
Primer: http://www.summitracing.com/parts/SUM-UP220/
Clear: http://www.summitracing.com/parts/SUM-UP200/
Old 01-25-2010, 02:05 PM
Official Solventologist
I have been told the Summit branded paint (Also Eastwood), primers, and clears are made by Kirker. I have never personally used those branded items, However, I have used Kirker products in the past and I never liked the Kirker urethanes for various reasons. They worked fine for some folks but I have had trouble of some kind almost everytime I've used it.
If you are looking for affordable refinishing materials with good quality there are other options out there like SPI and these guys, www.thecoatingstore.com. Valspar and Prospray also make some pretty good affordable stuff.
Old 01-26-2010, 11:00 AM
Tomlowe523's Avatar
Thanks for the response. I would buy something better, but I just need to shoot this truck and I don't really wanna put too much money into it, and I don't really wanna wait long, and Summit Racing is less than 5 minutes away from me, so this is just the most convenient option.
Do you guys see any problems with laying the Summit/Kirker clear over Sherwin Williams color?
Old 01-26-2010, 12:36 PM
wwilliams181's Avatar
The only thing i have seen with some of the cheaper primers is that they dont go as far and are somewhat hard to drysand. If you are planning on wet blocking you shouldnt have a problem. As far as your clear question.....you shouldnt have a problem using the Summit Urethane clear over sherwin williams base coat.
Old 01-26-2010, 10:16 PM
Tomlowe523's Avatar
Alright, sounds good. I appreciate your help.
Old 01-26-2010, 10:39 PM
No problem....Have fun with it!
Epoxy Primer & 2K Urethane Primer acquadigio79 Body - Exterior 17 08-15-2009 05:07 PM
Urethane 2x primer on bare metal Abby.Normal Body - Exterior 24 07-08-2007 08:23 PM
2k Primer, to Wet? satexasf150 Body - Exterior 2 05-19-2007 11:13 PM
Evercoat Slick Sand, Featherfill, G2, Polyester Primer Surfacer scrot Body - Exterior 6 05-27-2006 03:27 PM
summit racing mustang66maniac Engine 11 12-06-2002 04:50 PM
