Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Summit Racing LVLP paint guns?
Old 03-19-2013, 07:28 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Hooking the 2 compressors up will help, that will give you a holding capacity of 40 gallons, if you could get another 20 gallon tank giving you a holding capacity of 60 gallons and with both compressor hooked together even if the CFM output was embellishment was 25% you'd still be OK. Make sure you drain the compressor between coats of paint.
If you could paint whatever pieces you have first, you would be better able to determine if you'll have the capacity to paint larger surfaces without a problem.
The ideal situation now would be to get that extra 20 gallon tank...I would think that it would help your comfort zone considerably, I know it would mine...LOL
Ray
