summit starter install
Once you have the starter installed, be sure to use the Chevy knurled bolts. Take a big screwdriver and pry the bendix out into the teeth of the flywheel. Measure where 1 tooth of the bendix is centered between 2 teeth of the flywheel. Try .030 to start with.
