summit starter install - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2012, 12:44 PM
I just bought one of those liteweight aluminum mini-type starters from Summit Racing. Ive never used/installed one b4. The instruction sheet says I have to use a wire gauge to measure the...('lash??...backlash??'...WTF??...) between the starter pinion and the flywheel. I see it on the diagram, but how do I do this??...The engine is a '67 Chevy 396 BB, with a '71 Super T-10 4-speed in a '71 Firebird................thanx guys!!
Old 09-14-2012, 10:53 PM
Once you have the starter installed, be sure to use the Chevy knurled bolts. Take a big screwdriver and pry the bendix out into the teeth of the flywheel. Measure where 1 tooth of the bendix is centered between 2 teeth of the flywheel. Try .030 to start with.
Old 09-15-2012, 07:00 AM
Wiki Edits: 27
Paper clip.
Most guys say to use a straightened paper clip to measure. With everything made in China today I don't know how they are for size.
Summit mini starter 87monte385 Engine 2 12-09-2011 01:32 PM
how to install a starter tommy evans Engine 5 08-19-2010 08:04 AM
Hot starter... How to install ignition power interrupt switch on the HEI +12v Robby5323 Engine 9 01-04-2010 09:09 AM
Summit SUM-820323-M Starter Jake_Dragon Engine 2 02-10-2009 07:47 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
