Summit's 08600VS Carburetor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2010, 04:12 PM
Blue84JeepCJ7's Avatar
http://www.summitracing.com/parts/SUM-M08600VS/
I know have one of these on my Jeep! Its a bit late to ask but what ya think? It looks to be Summit's improvement of the Holley 4010.
Old 03-25-2010, 05:55 PM
Show me the money !
I used the 750 Summit carb on my 400 and I am happy with it. a little hesitation ( to be expected ) but Yeah it acts like my holley did. You can't ask more than that for the price. Time will tell.
Old 03-25-2010, 06:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are those sight plugs? The Holley I had didn't have those if they are.
The one I had was when the very first came out, a buddy got it for his Pontiac 400, w a medium cam, 3.73, TH350, a good street engine.
He liked it OK, but when it came time to tune it, he liked to have **** when he priced the booster cluster that has to be replaced to change the squirter size!
He did it anyway, and drove w/it until his desire for a lower ET got the best of him and he bought a Holley 4778 DP 700 cfm carb to replace it with.
So I ended up w/the 4010 in trade for some (more) work. I bolted it to my fresh 455 Pontiac engine for breaking it in- I knew it was in great shape and would light my new engine right up.
It actually stayed on the 455 for a couple months, through several drag strip Wednesday nights, and it did good- EXCEPT (isn't there always an "except") the carb bogged badly the first run of the night.
After the drive from the other side of the county (about a 30-40 min. trip), I'd get in line w/the engine off and push it forward as the cars ahead made their pass. By the time I'd get to the "on deck" point, I'd fire it back up and go through the routine. It wouldn't hesitate one bit through the burnout and staging process, but at the hit of the throttle, it would come out about 20 feet then lay down like a tired bloodhound.
It never stalled, but damn close- and if not for feathering it, it might have. But after the first run, it wouldn't do it again for the rest of the night.
The only thing I can figure is heat soak still got to it even though I had a blue Holley pump, insulated fuel lines, a wooden spacer under the carb, a scoop sealed to the carb pan built into the filter base and I left the hood open half way while in line.
I never did figure it out.
Old 03-25-2010, 07:10 PM
Kinda funny Cobalt...sorry about laughing at that!!!
Yes, those are sight windows. Right now what I have is a slight "hounddog"...lol... when making a tight turn or pulling into my driveway which has a slight hump, kind of like a speed bump but not as ruff. Would remind me of a float issue. Gonna give it a week or so then take it in if I need to for an adjustment.
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
Re-jetting with 4 hole carb spacer? stinky jinx Engine 11 07-13-2005 10:11 AM
Carb Lifter Plates? Nightfire Hotrodding Basics 11 05-05-2004 06:39 AM
one inch spacer? hcker2000 Engine 14 03-02-2004 08:49 PM
spacer plate what does it do? CurtisL Engine 5 11-02-2003 03:12 PM
