Sump Quantity ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2009, 01:27 PM
Sump Quantity ????
Can anyone tell me the correct amount of oil for a 76-79 305 SBC ????
The aftermarket dipstick registers full with very little oil and 3 times over the limit with only 4.5ltrs
Thanks
Old 06-13-2009, 02:29 PM
DoubleVision's Avatar
Your dip stick is not the correct one for your engine or it`s holder isn`t fully seated in the block. I usually install a quart in the filter then spin it on, then add 4 quarts there after. After starting to check the oil pressure and for leaks next I shut it down, let it sit 10 minutes then recheck the oil and add if needed.
Old 06-13-2009, 04:49 PM
ericnova72's Avatar
More for Less Racer
x2, it is a five quart system.
Windsor SB sump gasket type??? 67Mustang Al. Engine 2 03-29-2009 07:33 AM
dry sump oil system questions lowROLLERchevy Engine 7 11-23-2007 02:58 PM
Early Nova V-8 Oil Pan Front or Rear Sump ? yekoms Engine 3 11-25-2005 08:04 AM
What is the best way to run fuel lines from a sump. novadan Engine 2 10-04-2005 12:08 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 09:26 PM
