Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sun-dried plastic
Old 09-16-2006, 08:59 PM
gothrod87 gothrod87 is offline
GothRod87
a sugestion from a mini trucker
Another aproach if your wanting to go alil custom with it is to sand the messed up panels down smooth and use bondo in a couple of diffrent layors making sure to sand them smooth and build it up smoothed out and paint it to match your interior..seems alot easier then trying to recreate the texture and will hold up if you clear it pretty good..thats what i did in my old dodge and it is still as fresh as the day I redid them.as long as you try and keep the layers thin it wont be to heavy and it will last you the duration of the car as long as you take your time and pay attention to getting it built without high and low spots in the bondo.hope it helps,
GOTHROD
