sun super tach2 mdl7901 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2012, 08:07 PM
4 wires at back of tach which one does what? there in a north south east west positions, this is a old tach and the wires have all be replaced with black. also can this tach be hooked up to a flame thrower 2 coil? Thanks, harbor rat
Old 02-13-2012, 12:20 AM
327NUT's Avatar
Last place I read said the wiring diagram is inside the tach cup??
Old 02-13-2012, 05:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You might find the original wire colors at the point where the wires were spliced.
Typical tach wiring layout:
Black = ground
Red = 12VDC switched
Green = coil "-" terminal, will be the same terminal as the wire going to distributor
White = lamp
It will work w/the Flame Thrower 2 coil. If you are using an ignition amplifier, follow their instructions.
Super rare Pontiac super duty found on auction... F&J Hotrodders' Lounge 40 11-17-2008 07:37 PM
M-21 Vs. Super T-10 Fastest65 Transmission - Rearend 5 05-14-2008 11:23 PM
Super C RV? 428ho Hotrodders' Lounge 3 10-02-2007 05:31 AM
super t10? CRAZY681980MV Transmission - Rearend 3 08-26-2007 09:32 AM
TCI Pro Super Kit Houman SS '70 Transmission - Rearend 0 04-18-2005 04:29 PM
