Sun Tach light/perfromance problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2011, 10:16 AM
I have a steering post mounted Sun tach on my 66 nova having 4 wires needed to connect to operate--the red is connected to my fuse box, the green to the positive side of my coil, the black ground to the negate side of my coil, and the white is connect to the other dashboard idiot lights power source. The tach works fine until I turn on the light switch. At that time the light within the tach does not go on, the tach does not operate, going below negative, and my dashboard lights blink, not going out, just periodically dimming. I am thinking that that tach light is out, I have a problem with the head light switch, or when I recently put the engine back in the car, I put the ground of the tach to negative of the coil and it should be grounded to the frame, or i have a short in my interior dash idiot light wire harness...suggestions?? and if you think it is the interior light of the tach , how do I replace it--thx russ
Old 10-25-2011, 12:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Green tach wire goes to coil "-", not the positive side. The black wire is supposed to go to a chassis ground- NOT the negative side of the coil.
Old 10-25-2011, 12:36 PM
thx for the info...any idea why the tach would work without the lights on with the green wire on the positive side of the coil and the black wire on the negative side? Must have wrote doen the wrong wires to the coil when i replace the engine..thx, russ
Old 10-25-2011, 12:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have no idea- and it really doesn't matter, it was never designed to be wired that way in the first place so it's a moot point. Hopefully the tach wasn't damaged.
Good luck.
Old 10-25-2011, 01:00 PM
Thx for your solution...Russ
Please help with tach (light) cutthroatkid Electrical 11 01-29-2010 03:28 PM
tach light doesnt work 81scottsdale400 Electrical 8 01-27-2010 09:26 PM
Shift light, mechanical tach, msd 6al. commando57 Electrical 5 03-24-2006 06:16 PM
how can i get a JUST a tach light 53LEDSLED General Rodding Tech 6 05-27-2005 08:06 AM
tach shift light probenit Hotrodders' Lounge 3 02-12-2005 05:11 AM
