Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sunvisors
Thread: sunvisors
Old 04-11-2011, 07:27 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
The sun visors I showed were glued together and then sewn around the perimeter. You do all the steps I showed up until you use the sewing machine around the edge. You use high temp top and trim adhesive instead of foam to foam glue.
