My thoughts are why do you keep asking the same question over and over again? there`s more than one way to quiet down a exhaust system regardless of the mufflers used. a flowmaster, borla, hooker, all these sound good. if you exit the pipes out back behind the truck it won`t be no where near as loud as you think, I`ve rode in a friends truck that used straight pipes with megs megaphone exhaust tips with 4.11 gears, at 60 mph it cruised at 2700 RPM`s and you could barely hear it because they exited it out the back. if your running cat conveters with flowmasters with next to stock engine it shouldn`t be loud at all, especially if you use a cross over pipe to balance out the flow.
