super budget 92 camaro turbo build - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 06-22-2012, 10:05 PM
Project89's Avatar
figured id share a build ive been helping a friend with
this car stock ran 17.3 second 1/4 miles times all stock
the engine is a 3.1L 60*v6
the only engine mods are a 260 grind cam from delta camshaft and a set of home ported cyl heads that went on with the turbo.
the total cost for the turbo build is 900 bucks
with additional added parts the total comes to 1200 ( meth injection, 2500 stall converter,and adjustable fpr)
ok so heres the build
stock y pipe cut and capped on the end that would run to the cat converter
then we cut a hole in the ypipe facing the front of the motor
the we weld up piping to the front of the motor.
there is plenty of ground clearance and the pipe wont even rub on a speed bump
here is the turbo and wastegate mounted ontop of the pipe
temporary downpipe connecting to the exsisting factory ex system
downpipe and wideband location
Old 06-22-2012, 10:12 PM
Project89's Avatar
intercooler mounted up in the nose of the car
charge piping from the intercooler to throttle body and air temp sensor
complete shot
everything heat wraped to keep heat out of the engine bay and decrease spoolup time
the turbo is a 57mm t3/t4 hybrid capable of 450 hp
the best pass so far has been 13.3 seconds @ 102 mph, thats a gain of 4 seconds flat so far.
right now the injectors are maxed out so we cant push it anymore but a set of 50 pound injectors will be making there way in shortly
tuning is handled by the stock ecm but instea dof the stock code it is running the code 59 which is a modified version of the cyclone/typhon code
Old 06-22-2012, 10:26 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Threads not looking for technical help/asking questions belong in the lounge. Consider starting a project journal.
Semper Fi
Old 06-23-2012, 04:46 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Sweet project! I'm just starting to dive into the turbo world with my s10. How much boost is it running?
Old 06-23-2012, 07:21 AM
vinniekq2's Avatar
turbo
thats cool.I like the idea of turbos for the power they make.Unfortunately I love the sound of a big cam and free flow exhaust reguardless of the power.13 second quiet v-6 car is a great idea.How is the fuel economy when you keep your foot out of it?Do you know what the sfc is?
Old 06-23-2012, 04:37 PM
Project89's Avatar
without the meth injection it went 13.3 @ 12.5 psi of boost.
with the meth injection it backed up the 13.3 runs 3 times with only 10 psi of boost without changing the tune.
the main reason was the air temps were only 60-70* with the meth instead of 150* with only the intercooler
once the larger injectors get installed this thing should be capable of mid to low 12 second passes around 13-15 psi of boost.the limiting factor in how fast this thing will go with relativly low boost is the pre turbo ex piping
with real headers the car would be just as fast with much less boost
right now we run the car in open loop only mode and its knocking down about 28mpg highway.once the new injectors go in we will tune it and used closed loop which should bring that number up around 32mpg highway.
my personal car has the same motor and a slightly larger turbo, the main differences i made real turbo headers and i run a megasquirt ecm and i can knock down 35+mpg highway if i keep my foot out of it.
the biggest thing i belive that helps my car with the gas milage is i run a 3.73 gear vs the 3:23 . the 3:73's deff help intown driving to get the heavy car moving with much less throttle
sfc?
Old 06-24-2012, 03:04 AM
Project89's Avatar
well i wouldnt exactly call a v6 turbo car quiet
here is mine same engine different turbo and a cam ground to my specs with a 3 inch ex system.
my car has many ppl swear there was a sbc under the hood
if the video isnt working click this link
http://youtu.be/KXSkkf2DFUs
Old 06-25-2012, 03:30 PM
Project89's Avatar
heres a lil older video of the car running against a 07 3 valve gt mustang in a bracket race
car gets detuned for bracket racing to make it more consitant
Old 06-25-2012, 03:35 PM
Project89's Avatar
here is a 13.70 pass
ill have to resize the timeslip for the 13.3 pass and post it also have to find the video to go with it
but this comming weekend car should be well into the 12's if the new injectors get here intime
Old 06-25-2012, 07:30 PM
Listen and Learn
Wiki Edits: 7
nice ride. I gotta get my s10 together asap. Hopefully summit will ship out my fuel system stuff and I can get that in next weekend. after that its just bolting stuff together. What is the rear gear and tire size of your camaro?
Old 06-25-2012, 10:25 PM
Project89's Avatar
i switched form 3:73's to 4:10's
i also made the switch from a 26x9x15 slick to a 28x10x15 slick when i did the gear swap
on my friends car that im helping ( the car in the build thread) he runs a 3:23 with a 26x9 slick
he will be stepping up to a 3:42 or 3:73 set though eventually but nothing higher
i run the 4:10's cause i turn my motor to almost 8,000 rpms , he only turns 6500 rpms since his bottom end is not setup to spin as high as mine
my motor makes peak power alot higher then his due to cam and heads
but my car is still very very street friendly
most v8 guys will run a 3:23 gear with a turbo sbc
Old 06-26-2012, 07:00 PM
MXrider13's Avatar
The Dude
I love SBC set ups and to me there is nothing like the sound of a V8 but I really really loved this Turbo Camaro! I love to see guys trying different things with there rods.
Old 06-27-2012, 12:47 PM
Project89's Avatar
he has decided to step it up more now that he has 48# injectors on the way.
in the next week or 2 i will be building a set of proper turbo headers for him.
with the headers he should be able to run the same times with only 6-7 psi of boost compared to 11-13 psi
i also forgot to add on my 355 twin turbo iroc i am running a 2:73 gear and a 26 inch tall street tire with the over drive transmission. so far it runs great with the low gears , but i have nothing to compare it to yet.
i suspect with a th350 or th400 transmission it would be slugish in 1st gear but then again i sized my turbos for pretty much instant boost so........
Old 06-28-2012, 11:54 PM
spinn's Avatar
That is nice. A freind in the late 90's supercharged a grand am GT, but if i recall it was a 3.4L v6. Was real quick, high 14's at the track.
Old 07-03-2012, 07:05 PM
Project89's Avatar
got a lil bit of tunning done still needs a lil mor eon the electronic wasegate control as u can hear the wastegate cycling to control boost
0-100 was 12.5 seconds
The Following User Says Thank You to Project89 For This Useful Post:
against all odds (07-05-2012)
build thread, camaro
twin turbo 350 on a budget?? mikeweyman Hotrodding Basics 24 11-16-2010 11:03 AM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
budget turbo set up 409guy Engine 12 08-22-2006 05:40 PM
Turbo VS Super Icebergslim1827 Engine 29 04-24-2004 09:52 PM
super/turbo madhat Engine 0 06-22-2003 01:15 PM
