Super Flow Heads?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2006, 08:19 PM
Super Flow Heads??
I have seen Super Flow heads on Ebay and would like to know how good they are and compared to the the bigger names?
Old 03-20-2006, 09:53 PM
We had a set on the flowbench back in the fall. OUr results on a computer controlled Superflow bench were as follows.
At lifts .400 and under the were very poor, relative to a top of the line head like an E-Tec or AFR. Way better off with an iron Vortec if running a camshaft with .500 lift or less,Vortecs flow better. Above .550 they flowed like an E-Tec or AFR. Topped out at about 258 if I remember. This was a 200cc runner.
Moral of the story, they need chamber and bowl work to....well work across the board. You'd need quite a high lobe lift with a very fast ramp/rocker to get the valve high enough, fast enough to make some reasonable power relative to the top heads. If any head screamed for a 1.6, 1.7 or 1.8 rocker this is it.
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Are the flow numbers on these heads BS? Mad Maggot Engine 8 08-22-2005 03:02 AM
trick flow heads 4doorjoe Engine 2 07-30-2005 08:09 PM
Heads novatech Engine 10 01-17-2004 01:27 PM
993/997 Casting heads.....how well do they flow?? TheZaZ Engine 9 03-31-2003 07:30 PM
