Super lightweight clutch-flywheel combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 02:17 PM
Last journal entry: Summer 2010 Restoring the geometry of the body
Hello,
Thinking about purchasing lightweight(13.7lbs) steel flywheel(http://www.summitracing.com/parts/QTM-501101/) and LMC clutch kit from centerforce(http://www.summitracing.com/parts/CTF-LM161675/) for TKO600(faceplated) and sbc 383 , 4.1 re, 2.87 first gear
what do you think about this crazy combination? what problems should I expect besides high rev launches?
thank you
Old 04-11-2012, 03:04 PM
What kind of vehicle?
GM used the lightweight flywheel in 1980-90's f-bodies. The stock flywheel used to be about $150 new.
Old 04-11-2012, 10:53 PM
camaro 1969
406 balancer& flywheel combo sapsz28 Engine 8 11-07-2010 03:58 AM
Clutch/Flywheel Recommendation? mrdreex Transmission - Rearend 1 11-26-2008 01:12 AM
flywheel and clutch question gilliganspl Transmission - Rearend 6 08-26-2007 06:29 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
Lightweight vs Heavy Flywheel ezobens Transmission - Rearend 8 03-18-2006 07:05 PM
